20 year old boat, new to me. Today removed holding tank that had been installed w/diverter to seacock & no vented loop. Removing panels to access a place to mount a new vented loop, found the original one still in place. Loop was clear, vent of course clogged. Vent loop was tee'd into tank vent line w/1/4" hose, then out thru hull. The hose barb at the loop top only has a 1/16" hole. (This is a Wilcox Crittenden fitting.) Assuming I can adapt the right fittings could I, should I, have a bigger hole in the loop vent? I can't imagine a 1/16" hole staying unclogged for more than a month or two.Also, there was never a supply vented loop. I can fit one between the pump & the bowl but only get the top of the loop ~12" above waterline. It seems to me this would be preferrable to nothing because greatest danger is when the boat is on the mooring.Thanks in advance.
