Looking for plexiglass washboards for a Catalina 34
Aug 30, 2010
4
Catalina 30 Seaside Park, NJ
Does anyone know of a manufacturer of plexiglass washboards for a Catalina 34? Everything I've seen online talks about owners who had them custom made. Thanks.
Probably the quickest process would be to acquire them locally from a plastics shop. If you take wood washboards, they can be reproduced in plastic much quicker than if you try to order Marine Store units.
Here is a possible site. https://njplastics.com/
Likes: Timm R Oday25
Jan 4, 2006
7,723
This kind of washboard ................... ?
First time I've heard that term used for hatch boards.
I would presume that hatch boards are a custom fit for every individual Cat 34 (year unknown) boat as the dimensions for each companionway entrance are going to vary +/- 1/8." This would make for a poor fit if the boards were not custom cut for that particular boat.
Hopefully, you've still got your original hatch boards which are likely plywood or jointed solid wood stock. If you're set up with a good workshop, you can use the boards as a pattern for a profile Dremel bit. For the horizontal joint faces between boards don't use a rabbet joint as the wooden boards use. Use a 45° mitered butt joint but along the two mating edges.
If you're not set up to fabricate your own from acrylic, my choice would be to take your original boards to anyone who sells acrylic stock and get them to copy the boards, dimensions, joint angles, the works. I know that many suppliers of acrylic stock also offer simple, uncomplicated machining of their products as a real money maker. A more expensive choice would be a Plexiglas fabricator using a C&C machine. My boat has three acrylic boards, factory installed, each 3/8" thick.
Jun 11, 2004
1,928
Oday 31 Redondo Beach
Hmm. Washboards is a common term used interchangeably for hatch boards around here. I wonder if it is a geographical thing?
Anyway, if you had a pattern I would think most any local plastic shop would be able to make them up to your specs.
Jan 4, 2006
7,723
What's so funny :soapbox: ?
There's no way we can fit a washing machine into our H-310 without permanently moving everything out onto the deck so this is what we use for laundry.
That's Ma doing the Monday morning wash. I want all of the sails washed out by Monday night, too. She's a good 'ol gal with a few crossings under her belt but she's still goin' strong.
Ah, ain't sailing just grand ?
May 7, 2011
239
Catalina 36 1430 Lake Lanier
I made my own companionway doors. For my previous boat, a Catalina 30, I used Cumaru (Brazilian Teak). For my current boat I used PVC trim lumber. I measured again for my 36, but basically used this:
The Cumaru doors had removable slide in inserts for clear or opaque and also had carved dolphins. (My late wife loved Dolphins)
The current doors have permanent plexiglass and solid inserts for privacy.
Oct 29, 2012
357
Catalina 30 TRBS MkII Milwaukee
I built a frame out of mahogany to accommodate the thickness of the original hatch-board and using it as template made a framed clear "board" for the top board as a window to let in light and keep out weather.
Since the nice clear plexiglass was considerably thinner just put a rabbit on the insider of the frame about 3/8" and carefully epoxied the plexiglass to the wood before varnishing to match
Mar 2, 2019
674
Oday 25 Milwaukee
I've been using 3/4" Lexan hatchboards for the better part of 20 years . I really like the light these let in .
Especially on gloomy and rainy days . At first I was concerned about privacy and long term UV exposure .
Turns out I need not have worried about either issue .
I haven't figured out how to remove the many small scratches .
Lexan has proved to have been a great choice for durability
