looking for new exit blocks for the mast rebuild
643
SCHOCK santana27' lake pleasant,az
the ones i have are all plastic sheeved and are trashed.i want metal or phenolic sheeves no more plastic but i cant find them the only ones i found are plastic. i have phenolic ones in the masthead and their fine
Joe
Jun 1, 2004
8,318
go here
http://www.rigrite.com/Spars/SparParts/Exit_blocks.html I googled "exit block for sailboats" and this site looked like a good place to start.
Scott
Just curious ...
Do you have a need for an exit block? The turning angle would be more than 90 degrees. If your line is exiting in the same direction you would need just an exit plate. For instance, on our boat the internal halyards exit the mast with plates and turn at the blocks outside the mast at the base. That seems like the normal circumstance to me. Rig Rite does have a comprehensive selection of parts for your mast, but be prepared for their prices. I bought a new mast base block for a spare halyard. I was going to buy a couple and discard an older one that wasn't turning well. After choking on the price, I worked much harder at restoring the older block instead.
Sep 19, 2006
643
scott your probably right but
the ones i have aren't the right ones and their pretty messed up
