Looking for info about my new Oday
JJG jr
Dec 9, 2012
4
Oday 19 Mariner 2+2 Falmouth Ma Cape Cod
Hello,
I recently bought an Oday. I am told by the sales slip that it is a 1972 but it doesn't entirely match up with others I have seen. The cabin on this one seems a bit different than others I saw. Is there anyone that could help tell me more or less which model I have or any details about it. I just bought it over the weekend and am excited to learn all I can.
Thanks
Jim.
Erieau
Apr 3, 2009
209
Oday 25 Erieau
I see the forward deck hatch, and that says something about the year. I can't remember what, though.
Seems to me the hatch was added in later years of the Mariner run.
I read this a while back on the Class Association site.
Also on the site is the Secret Decoder Ring for your Hull ID number, which will unequivocally tell you the model year.
Jun 2, 2004
1,957
Oday Day Sailer Wareham, MA
This is definitely a MARINER, model year in the 1969 to early 1972 range. The deck design was changed to the one now used by Stuart some time during the 1972 model year run. This version was more or less an update of the original Mariner design from 1962-68. for 1969 the cabin was enclosed with an aft bulkhead and the cockpit became self-bailing. This change allowed 2 aditional berths inside the cabin under the cockpit seats, the forward berths that originally were 2 singles meeting near the bow, now was changed to a V-berth that slept 2 persons, hence...2 + 2 and the Mariner 2+2 was born. The cabin trunk shape design (stepped) was more or less carried over from the older 2-berth version keeping the forward hatch and adding a sliding hatch over the companionway (cabin entrance). When the deck was redesigned (to single level) sometime in 1972, the forward hatch was eliminated.
It is dificult to "nail down" the exact model year of most O'DAYs built prior to 01November 1972, since the older boats did not have the 12-digit HIN that includes the model year in the code. Boats built prior to the HIN requirement that started in November 1972 had 2 numbers to ID them, a Hull# that was based on total boat production of all O'DAYs, and a CLass# that refered to how many of that class had been built (in this case Mariners). O'DAY seems to have phased in the HIN on their boats and so it is worth looking on the outside of the transom near the starboard side for a 12-digit code that will start with "XDY" and end with (usually for this vintage) the last 2 numbers in the 12-digit code being the last 2 numbers of the model year ("72" for a 1972 model).
JJG jr
Dec 9, 2012
4
Thanks for info. I found it to be a 1070 because of ID# 1865. Now i have a question about what type of trailer to use. It came with a trailer POS not worth fixing and wood planks for bunks. So any info would help. Thanks again.
mjp83
Jul 11, 2012
31
Catalina C22 Trailer sailer
Jim,
Congrats on an awesome purchase. This is a very easy sailing boat, and this forum is by far the best supported!
I did a lot of work to my 2+2 based on Nat B.'s boats web page, " Orion". http://www.nathanbayreuther.com/mariner/boat.htm
Excellent info can be found there.
My trailer is a magic tilt, with wood bunks. I have seen people take speed boat trailers, and raise or add bunks. You need to make sure the boat's rear window sits over the axle to make the tongue weight about 200 lbs.
Best luck.
269
Oday and Catalina O'Day 25 and Catalina 30 Milwaukee
Why not fix the trailer?
Jim -
Congrats on the new boat. A little elbow grease will make this a fine looking boat. Make sure to post your before and after pictures. I always like seeing the transformation.
Concerning the trailer, you can buy a new trailer but I would see if you can find one of those small firms that specializes in trailers to just fix the one you have as long as it's structurally sound. Shoreliner trailers have been used for a lot of O'Day's over the years, and I've had two of them that have worked fine for the 222 I had and the 25 that I now have. While I always made sure the trailer was in good shape and I even added electric brakes to the single axle trailer for the 222, I would prefer to spend money on the boat rather than sink a lot of money into buying a new trailer. If structurally it can't be fixed, then I would look into a good used trailer that can be modified for your needs.
Good luck with the boat and trailer.
Dave
s/v Lagniappe
O'Day 25
JJG jr
Dec 9, 2012
4
Thanks Dave, Is it possible to use a roller trailer or should it be a bunk trailer.
Jun 3, 2004
269
Hi Jim -
Either can work. My O'Day 222 had rollers that left little indentations in the hull so I swapped them for bunks. I never had any problems with the bunks and the indentations worked themselves out. I think the indentations could have been just a problem with the height of the rollers. The keel should be taking most of the weight of the boat, not the rollers. One advantage of the rollers is that it is easier to apply bottom paint with the rollers. I eventually bought some boat stands which allowed me to get under the bunks for the bottom paint
The 25 has rollers and they work fine. Looking at the pics you posted and the one by mjp83, it looks like both of these trailers are setup with bunks. I don't see a significant advantage to switch to rollers as long as the bunks are appropriately positioned.
Dave
s/v Lagniappe
O'Day 25
