Looking for Aerogen Wind Distributor in the USA.
19
- - New Bern,NC
Looking for Aerogen Wind Distributor in the USA. Also any suggestions in wiring wind Generator........... Thanks
F
FP
US DISTRIBUTOR
Made by LVM Ltd US Distributor according to LVM Web site JSI Johnson Sails Inc Tel: +1 727 577 3220 Fax: +1 813 576 1306 e-mail jsi@jsisail.com
May 11, 2005
3,431
Seidelman S37 Slidell, La.
Wiring Wind Generator
Chuck the wiring is simple. You need to find the positive lead, which should be red. You need to place a big diode in the positive wire, with the current flow towards the battery. Now hook the red up to the positive side of the battery, and the black to the negative side. It's that simple. Most will also intall a regulator between the positive output of the generator and the battery. Some wind generators have their own regulator built in, some don't. Some put out to much voltage and can fry batteries without a regulator. I would recommend installation of a regulator, but in a pinch, a simple on off switch will work, if you watch battery voltage closely.
Jul 11, 2006
19
- - New Bern,NC
Thanks but outdated info on USA distributor
Sadly the website info is outdated. I called all around and cannot find a USA distributor. How do I cross match to get a regulator to work?
