Looking for a Replacement Anchor Roller Wheel
Jan 6, 2014
89
Pearson Triton Cambridge
Hi All,
My anchor roller wheel is pretty beat up and doesn't turn well. I'd like to replace it.
The dimensions seem a bit uncommon. I've been looking online for a replacement but no luck.
4" diameter, 3 1'2" wide, 3/4" diameter inner hole.
Any suggestions where I might look? I can't find anything.
The roller itself says "AB Industries ABI". I think they are out of business?
2,182
I used one of the yellow plastic rollers from a boat trailer. Had to trim the sides very slightly to fit, but it has held up very well
You can just see it in this picture
2,191
Perhaps some wandering thru the vast warehouse-on-line at McMaster-Carr is in order??
Feb 10, 2004
4,184
Hunter 40.5 Warwick, RI
Sully75,
Check with Phil at SBO. He has a solution that he is about to market that may help you.
Tim R.
May 27, 2004
3,626
Buy some round Delrin stock in the appropriate diameter, cut to length and drill. You can get it machined cheaply if need the hourglass shape. Will probably outlast your boat.
If Phil doesn't have it, try Catalina Direct. You also don't really need the hourglass shape if the sides of your roller are reasonably high. The other suggestions are good, too. Good luck.
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
you can also try zephyr works in washington state they will make you whatever you need
capta
Jun 4, 2009
5,008
I'm with those who suggest the boat trailer rollers. We've used the hard yellowish ones with great success, getting at least 3 years from them for just a few bucks. Our anchor is 88#, with all chain and we are anchored almost every day of the year (except for a one week haul out). When the yellowish ones weren't available, we tried the softer black rubber one and it failed in just a few months.
