It eludes me why the Raymarine Smartpilot is not smart enough to calculate true wind speed from SOG, once the latter is fed thru by the GPS via NMEA.
My query to Raymarine produced this reply:
“For True wind data you need to have Speed through the water, not SOG. Using SOG and Apparent wind is a completely different calculation called Ground Wind.”
Surely, once the SOG is available, it should be relatively simple to for the computer to switch and calculate from that data, especially if STW is not available due to a fouled paddlewheel. I would think that the formula would be the same and the result would certainly be more accurate.
Is there a more intelligent answer than Raymarine’s on the subject? I noticed on the search facility that Witzend had a similar query some time ago.
