i purchased a 18.5 1989 and although there ios a cord from the mast to plug in the deck, there is no mast light on it.where is it located? where can i find the part?
The light you are missing is probably the anchor light. It should be located at the very top of the mast, if you are at deck level you prob. wont even be able to see it.If it is the steaming light it will be on the front of the mast about 2/3 of the way up.
