The original specs for my 1983 Catalina 36 show the cockpit drains exiting down below the transom, under the boat, with a large outside circumference nylon bilge drain outlet in the center of the lower transom. But oddly, my boat has all three outlets right in the transom, smooth finished, no nylon bushings or any such add-ons. I've seen one other boat of my vintage with the same configuration. Was this a factory job, an owner mod? Anyone have any clues? Just curious. See attached image. You can also see my added swim step.
