location of air conditioner sea water pump trigger
Jun 14, 2007
181
Hunter 45cc Florida
I have a 2005 Hunter 45cc. Does anyone knows the location of the trigger switch (relay) for the air conditioners sea water pump
Jun 1, 2009
1,869
Hunter 49 toronto
Ok,, here’s what Hunter did on the 49s, which I assume is the same on your boat.
The cooling water on the airco units runs in series through the airco units. So, if any airco is on, water flows through all units
The way this happens is there is a relay box that switches on when any of the airco units are energized. The water pump is powered from the contacts on these relays, which are essentially in parallel
Hope that helps !
Sep 30, 2016
398
Island Packet IP 44 Ventura, CA
If you have one AC unit, them typically the pump is triggered from the unit. If you have multiple units there will be the relay device, like artboas described, probably located someplace convenient (for the installer) between the two. It may look similar to a junction box.
