Hello,
Does anyone know where to find the second Hull Identification Number on a Hunter 460?
I know:
Thank you.
Fair winds,
Rob
I know:
"After August 1, l984, boat manufacturers were required to display two identical Hull Identification Numbers, one on the outside starboard side of the transom, within two inches of the top of the transom, gunwale, or hull-to-deck joint, whichever is lowest. ...
The second HIN must be inside the hull in an unexposed location or beneath a fitting or item of hardware.
The HIN characters, both inside and outside the hull, must be no smaller than ¼-inch high, but many manufacturers make them much larger. It is illegal for anyone to alter or remove one of these numbers without written permission of the Commandant of the Coast Guard."
I've looked from stem to stern without luck.The second HIN must be inside the hull in an unexposed location or beneath a fitting or item of hardware.
Thank you.
Fair winds,
Rob
