Tim
I will be sailing for the first time an Ericson 29 in Maine waters, the land of a million lobster pots. The boat has a swept back keel and a rudder set back from the keel with the prop in between. The rudder is mounted on a post on the rudder center line. There is a space between the hull and the fore part of the rudder, a perfect spot to trap a line.What have people done to prevent this other than the obvious don't run over any lobster pot lines. Would it work to run a cable between a point on the aft of the keel to a point on the bottom of the rudder that would not affect the turning of the rudder. The idea being the line could run along the cable all the way past the boat harmlessly. Might this work?
