Little is not insignificant.
SFS
Aug 18, 2015
2,092
Currently Boatless Okinawa
I must be missing something. Based on the picture, it would seem this would hinder, not help, unlocking the line from the cleat, by limiting the distance I can pull straight up. How does this improve things?
Oct 26, 2008
6,432
Catalina 320 Barnegat, NJ
I think the guide enables one to lift or set the line from just about any angle. It looks like a good addition. I have a similar condition and to release or set, I have to get my hand directly behind the cam cleat. I don't think the loop restricts the upward pull.
SFS
Aug 18, 2015
2,092
Thanks Scott, that helps, I think. You don't have to take the time to line up the "rope" with the gap between the cleat halves when re-cleating. The efficiency gained does not occur at the uncleating step, it occurs at the re-cleating step.
Oct 26, 2008
6,432
I bought a harken cam cleat with the guide for an application that I haven't installed yet. I didn't really know what the guide was for. Now I know! :doh: Now I have to figure out how to add (or if I can add) this to the traveler cleats (Schaefer double sheave w/cam). Those are the one's that Sue can't seem to master because she doesn't line it up right.
Jan 8, 2015
360
MacGregor 26S, Goman Express 30 Kerr Reservoir
SFS it does help with the uncleating as well. I recently installed them on my jib sheet cleats. Now I don't have to go to the low side of the boat to adjust the sheets while on a significant heel.
Jul 7, 2004
8,534
Hunter 30T Cheney, KS
This is a brilliant tip. My line constantly gets behind a cam and takes more time to sort it out. I think my traveler cleats are Schaefer.
Gunni
Mar 16, 2010
5,937
I put fairleads on all my dinghy sheet cam-cleats. You can use a line-"whip" technique to bring the sheet out of the cams but still contained and ready for re-set. Put a figure-8 knot in the end of your sheet and you never have to go looking for the line, it remains on the cleat.
Gunni
Mar 16, 2010
5,937
That would be an upgrade but a strap AND fairlead make it very easy to guide a line into and out of the cams.
Ronstan version:
Likes: Scott T-Bird
Oct 26, 2008
6,432
Ronstan version:
That's the one I think I would want. I'll have to see if the fastener holes will match. First, I'll have to see if Schaefer has the the same thing (but I haven't seen them in their product selection). I've got the eye straps on my traveler cleats, but Sue still has a problem with it.
Jul 7, 2004
8,534
I found eyestraps to fit my Schaefer cleats. Funny that I couldn't find Schaefers that would work. Went with Harken HAR137. Fairleads would have been nice but just capturing the lines will make a huge difference, especially single handing. (is it 'handing' or 'handling'?).
