Jeff
I have an 88 33.5. Last year I installed 2 pairs of golf cart batteries at the bottom of the lazerette after building a floor for them. I placed them as low as podssible. Worked well. I noticed afterwards that I had a port list so I glassed in some lead ingots under the aft bunk. I added about 360 pounds keeping them as far starboard as possible. Yet, I still have a slight list to port. With the fuel and holding tanks both located on the port side already, is there a natural port list to the 33.5's?I also needed to add some ballast at the bow after adding the 600 lbs or so to the stern. I added 120 lbs just forward of the water tank but the stern still sits a little lower, especially as the water tank empties, so I may add a couple ingots, (60lbs each), in the very forward compartment.Any ideas folks?
