Lip Seals
Aug 24, 2014
149
Aphrodite 101 148 Coeur d Alene ID
Any suggestions for finding replacement seals for the prop shaft. I'm looking for a replacements for GACO DPSM 25357. The contain a stainless steel spring. Not sure about the numbers. Hard to read.
Thanks!
Mar 20, 2012
3,983
Here is a Link showing suppliers of seals and bearings in your area.... Applied Industrial and McGuire are both proven suppliers..
the stainless steel spring is common to a lot of lip seals...
Nov 6, 2006
9,904
Numbers are universal size designators.. so a 25357 is a seal with 25mm ID (like for a 1" shaft) the Outer diameter is 35mm ; that is the size of the recess it fits into.. and the seal is 7mm thick. The other designators aren't standard but probably are markers for the elastomer material and the metallurgy of the spring and whether it is double or single lip.. As Centerline says, a reputable supplier should be able to cross reference to another brand easily..
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
if you highlight the part number you typed on here and then search with google a lot of sources pop up
Kermit
Jul 31, 2010
5,657
My wife would be interested in one of those for me. :-|
