Bill Welsch
Just installed a Link 10 battery monitor on my C 350. It appears that I wired it correctly since I can turn on an appliance and watch as the Link 10 shows me the negative amp flow (-6 amps for the refrig, -.8 for lights, etc). Also, when I am plugged into shore power, I can see the positive amp flow, ususally 8 amps or so.The perplexing thing is that I dont see positive amp flow when the motor is running, despite the fact that the voltmeter at the nav station (orig equip with the boat) shows in the "charging" range. Furthermore, when I switch the Link 10 to the Volts reading, it shows--when the motor is running---a much higher number than when the battery is "at rest" (14+ versus 12.7 or so "at rest.")Anybody have any thoughts on this? I plan to call Xantrex (makers of the Link 10) but they only provide 15 free minutes of consultation so I'm trying to learn as much as I can before I call. And, yes, I have Nigel Calder's book and will review it for help with this.Thanks for the help.Bill Welschs/v "Escapade"
