steve
This is my first post so please forgive any mistakes. I own a 1982 catalina 27. This my first boat and despite numerous learning experiences with it (i.e. mistakes), it has been a good sailor and great fun. However, I am 58 years old with arthritic knees with a spouse who is a reluctant and anxious sailor. She hates it when I go forward to raise the main leaving her in the cockpit alone, and although I am still fairly limber, my knees get worse each year. For reasons of domestic tranquillity, health and safety, I would like to be able to raise the main from the cockpit. My boat has midboom sheeting, with a curved traveller which rests on teak blocks at either end of the companionway. The companionway is wide and there is a raised cabin top with teek handrails down either side of the cabintop. As a result there is little space to run lines down the sides of the cabintop, and the lines have to go through the teek risers. I also have a 150 genoa with roller furling. I would love your advice on how to set up the boat in a way that will be efficient and cost effective. I also do want a system that sounds good but makes things worse. I would consider doing some diy if feasible. I see 4 options in ascending order of expense and difficulty. 1. I do nothing and just live with what I have. When my knees really do get bad, I just buy another boat or sail with a young crew or sail with the genoa only. If it anin't broke...2. I just run the halyard back next to the mainsheet and put a hole in the riser to get the line to the starboard winch (the only winch on the cabin top). The obvious problem is that this would leave the reef lines at the mast. I would note that I have owned the boat for 3 seasons and have never had occasion to reef the sail. I assume that that would not last forever, although all of my sailing is in the mid chesapeake and mostly in the summer.3. I could run the halyard back and then set up single line reefing. That would allow me to bring just 2 reef lines back to the cockpit, probably on the port side. However, would I need to install a second winch on that side? I know that many people do not like single line reefing, but it seeems to work for others. 4. I could run the halyard and 4 reef lines back. This would probably require me to get rid of the teek risers and put the traveller on metal risers (Garhauer offers such a system.) This might be the best solution, but probably the most expensive.I have purchased a rigid boom vang although I have not installed it as yet so I am not worried about bringing the topping lift back. I do not have a cunningham. I would appreciate any advice that any of you can give me. I woud be delighted to entertain any additional options.
