Well crap...
I hadn't even thought about the lines being in the way when moving forward. Not that everything else isn't in the way already. As far as the jib goes though, I had planned to run them inside the lines for that so as to keep them from rubbing eachother or tangling.While Paul's pictures are great, they are just not possible on the cabin of the 22 without the lines rubbing. As you can see in his pictures, they rub past the rails for the sliding hatch, and this would just be even more exagerated on a 22.Ed may have the best idea, to remove the handholds. Then, replace new ones working around the cabin top and all the new equipment you just installed.My idea, while unorthodox is all that I could come up with that used the existing winches. The only place that the line would be in the way any more then any other line would be where it goes from the cabin top to the deck. I may have to rethink my ideas, because the fact that the lines whould need to be stepped over hadn't crossed my mind.The only other possiblity that I had come up with was to run one halyard each way along side the sliding hatch. Something like Paul has done in his pictures, except with only one line and a winch on each side. There is room perhaps for one line, but I think if you go with more they will just end up wearing through each other or binding up because of how cramped it is.My problem was I couldn't afford to place a winch on each side, and wanted to come up with a way to use the two existing on each side of the boat. Although if you don't want a winch to tighten the sails with, this might be perfect for you. Block at the base of the mast, a single block deck orginzier similar to what Paul's pictures show, and just a rope clutch or something on each side of the hatch. Remember, if you use a boomvang, you will want to take into concideration that third line. There's limited deck space, and not a whole lot of room to play with. Hopefully someone will respond with the perfect idea...Josh
