Lilfelines for O'day 23' year 1973
Jim B
I purchased a 23' 1973 O'day and the lifelines were not on the boat...I was wondering if anyone has a picture of a 23' 1973 as to how the lifelines are positioned? Also can anyone tell me how easy or hard they are to install as I have to get new hardware. Thanks, Jim
Mike
Not standard
I don't think lifelines were standard on the 23 back in '73. The early '70's 23's I have seen that had life lines had a bow pulpit and two stanchions per side. The lifelines attached to the pulpit down low on either side (via a welded eye), ran through the two stancions and then was secured to a pad eye on the deck about halfway down the cockpit. I don't know if Oday even offered a stern rail as an option back then; I have never seen one on a 23 that old. If you have one, maybe the lifelines attach there instead of to a deck pad-eye. If there is a welded eye on the rail, that's where the lifeline goes. Attaching life lines is very easy; you will need to completely unscrew the turnbuckle from the line in order to fit the line through the holes in the stanchions, but fastening the lines at either end is a piece of cake. Since you are buying new lines and hardware, I would recommmend going with quick release fittings at the stern. This will make it easier to remove the lines to board your boat (both at the dock and while at anchor). Well worth the extra few bucks.
Jim B
Thanks Mike
Mike...how down low are the lines less than what I hear the standard 24"? Jim
Mark R.
Oday 23 lifelines
Jim, I have an 1972 Oday 23 myself. I do have a personal website about my boat with pics on there. Maybe something there will help you. My boat has four stanchions and a bow pulpit.
Jim B
Mark R. Need link to your website
Hi Mark...Thanks for the info...could I have the link to your website so I can see your boat...appreciate it. Jim
K
Keith
Bow Pulpit + 4 Stanchions Were Standard
I also have a 1973 O'Day 23. The lifelines on my boat are original, and match the pictures on the original brochure that I have for my model. The boat has a bow pulpit. No stern rail. Side lifelines are a single white covered cable from a padeye on the deck a foot behind the bow pulpit return, through a forward stanchion, through a rearward stanchion, and down to a padeye on the deck just in front of the end of the jib sheet track. My memory is that stanchions are about 20" high, but I should measure if you need this. This same arrangement appears on several of the early 1970's vintage boats in pictures on this site and others. Hope this is helpful.
