The instrument panel have 3 red lights in the Y25MKii... which should go off after the engine starts.
However, nothing is said about what will happen, or what the meaning, if they stay on.
Water intake light - if on after the engine start should have any problem with the water to cool down the engine ?
Oil light - if on after engine start should have low level of oil?
Battery light - if on after engine start means the battery is low? Problem with the alternator? OR just mean it's charging and then will go off after the battery is full?
I tried to check this in the manual but no detailled info
