static charge dissipator
have some more info on the static charge dissipator, wasnt able to get the manufacturers name however this unit looks like a tube with small stainless steel strands coming out of it. it can be secured to the mast with two screws making sure you have good contact with the mast, no paint, metal to metal with di-electric grease. no other electrical wiring is needed. all the equip that was lost on friends boat had external wiring thru the mast. it seems like a quick disconnect for all the high dollar stuff might be some good insurance when not in use. i've got a hunter 22 in the driveway and i made some supports to keep the mast supported about 18" inchdes over the top of the cabin and i am able to work around it without too much trouble. i support it at the bow, stern, and at the mast step. personally i believe unless you have a lot of electrical gear on board, lightning is not a big issue. keep in mind that favor with God Almighty is inversely proportionate to getting struck by lightning. Keep it clean. dpat
