Capacitance & Lightning
Capacitors & Lightning:Arlyn’s dielectric analysis of how lightning attaches to a boat, while (perhaps) emotionally appealing, neglects several important issues, and represents a gross over-simplification of a very complex phenomena. While I'm not prepared (nor perhaps competant) to get into a complete scientific debate of his contentions, I think it important to respectfully challenge this posting.For further consideration:The potential difference between a thunder cloud and ground (in our case the water), which results in a lightning strike, may vary between 100 Thousand and Many Millions of volts. A lightning strike will have traveled up to 10's of miles, across wet ionized air, prior to attaching itself to ground (through your mast or otherwise).A lightning strike is not merely a “DC” (Direct Current) event. Because of the very rapid (about 1 millionth of a second) build-up of current, from zero to as much as 300 Thousand Amperes, lightning is also an “EMP” (Electro-Magnetic Pulse), or “RF” (Radio Frequency) event. A typical (if such a thing exists) lightning strike is not a single episode; but consists of a sequence of several events . There are the:- connection (attachment) of the stepped leader from cloud to ground streamer- return stroke (huge amperage, very short duration)- continuing currents (smaller current, longer duration)- subsequent leader - return strokes & etc.While Arlyn is entitled to his opinion, and to draw his own conclusions, I think it important to point out that his logic is not in keeping with the overwhelming body of scientific thought on the subject, which may be summarized as:- Lightning is capricious and unpredictable.- It is impossible to effectively isolate (insulate) a boat from ground (water).- Bonding does NOT appear to increase the likelihood of being struck by lightning.- Bonding IS likely to decrease the damage caused if lightning strikes.In short, I’ve found no scientific evidence to support the contention that “grounding a boat shortens the path to ground”, and a great preponderance of counter-opinion.A very short bibliography:http://www.thomson.ece.ufl.edu/lightning/SGEB17.htmlhttp://www.cdc.gov/nasd/docs/d000001-d000100/d000007/d000007.pdfhttp://www.thomson.ece.ufl.edu/lightning/IEEE.pdfOMORespectfully,Gord
