A Belt & Suspenders guy?
While a good lightning mitigation ground (bonding) system is certainly a good idea; I’ve never considered bonding my boat in the cradle. In the cradle, she’s ALMOST isolated from ground, so the potential for a ground strike is pretty low. I do disconnect & remove my portable electronics & batteries, and disconnect my built-in electronics.However:You could effectively ground your boat:~ Install two (2) 3/4" x 10' Ground Rods, ten feet (10') apart from each other, and near the boat cradle.~ Using #4 AWG minimum copper cable, bond the 2 Gnd. Rods together (series), continuing up to the mast or lightning ground plate (if so equipped). ***It just occurred to me that you may be on a metal cradle or jack stands (I’m in a wood cradle) - in which case maybe you should ground your standing mast.***Regards,Gord
