Lifting Struts on Engine Hatch.
Jan 2, 2015
35
Beneteau 340 Oceania ventura
I have two struts on each side to lift the engine hatch. I believe they are 40lb + lifting powder.
They're so strong they're braking their mount brackets. I took them off and tried to compress them manually and they wont budge with my weight. Does this mean they're shot.
If the hatch is 40-60lbs how strong should they be.
Any sources for new ones.....
Gas struts from AutoZone or someplace. Same as the "Marine" ones at half the price.
from a post in Feb 2014
Gunni
Mar 16, 2010
5,937
My engine cover uses a single gas strut, rated to 90 lbs. There is a lot of force on those mounts, they should be through-bolted to a stout attachment. You can find replacements McMaster-Carr. www.mcmaster.com
They are sized by lift lbs, length, and end attachment type.
