Lifting Sling Points for Hunter 40.5 - Help
Oct 26, 2010
2,106
Hunter 40.5 Beaufort, SC
1994 Hunter 40.5
My hull was repainted and the sling points are no longer marked on the hull. I"ll be going into the yard in January.
Does anyone have the locations for the sling available. If you could give me a reference like X Ft Y Inches aft of the miship cleat centerline or some such other easily identified point I'd appreciate it very much. A picture would be fine too.
Thanks in advance
Feb 10, 2004
4,096
Hunter 40.5 Warwick, RI
Dan-
Here are a couple pictures. You can count the toerail holes from the stantions to locate the correct points. The important location for the stern sling is that it DOES NOT go under the keel. It must go around the hull.
2020_1105_113912.JPG2017_0613_065352.JPG2016_0510_091958.JPG2004_0506_073244AA.JPG2004_0506_073258AA.JPG
Oct 26, 2010
2,106
Hi Bill. I've been following your and Yvonne's posts on FB. Those grandbabies and Spud are really cute! Let me know when you are hading this way again.
Dan
Feb 21, 2014
137
Hunter Passage 42 St Andrews Scotland
I wi
Dan
I will Dan. Lots to do on the new Casper but, at least I got my Hydrovane
