Lift points
May 30, 2006
1,075
You must use two straps, but be VERY careful of the forward one due to
the cut away keel of the bow. Not sure how much forward of the mast it
was when I did it, but lift partially and watch for slippage.
Hal
Harold J. Kearsley
114 Denning Road
Randolph Center, VT 05061
802-728-5792
________________________________________________________________
Speed up your surfing with Juno SpeedBand.
Now includes pop-up blocker!
Only $14.95/ month - visit Juno Internet Service- Value-priced Internet Service Provider - ISP - Free, low-cost and fast Internet Access to sign up today!
Oct 31, 2019
562
Hi.:
just make sure the rear lift strap is not on the rudder...
the forward one should be on the keel.. but that depends on
the lift- I had my Vega out dozen's of time.. never had a
problem.
Wilhelm, V-257
Nov 8, 2001
1,818
Hi
In the UK we tend to get the aft strap as far forward as possible above the prop in the gap between hull and prop. Ensure you do not get the strap on the prop as I have seen a few Vegas lifted that way and ends up with a bent shaft and expensive repair. The forward one is located at the chainplates for the forward lowers. Ensure both straps are also tied together to stop any slippage. Once you have lifted the first time,mark the Vega with stickers so you will know in the future where to lift.
Hope this helps.
Steve Birch
