Lifeline Stanchions for Seaward 17
Feb 26, 2019
68
Seaward 17 Ohio
Looking for information about stanchion geometry. I'm particularly interested in the angle at which the stanchion sits once mounted. On my S17 port side, the aft-most stanchion appears to be angled amidship more than the stanchion on the starboard side. There's no evidence that it has been bent. Would it be a mistake to reverse it so it angles to port? The mounting screws line up perfectly. Or should I look for a replacement.
If we can assume that the stanchion fits into a mounting plate, and is not one welded piece, then either the plate is bent or the deck is not the same level as the other side. It wouldn't be a mistake to reverse it but I'd rather have it face inboard than outboard if I am understanding your question. It would still be angled and would not look straight. I would inspect the deck around the angled stanchion. A picture would help.
