My Catalina 28 MK-II had two lifeline stanchions bent as a result of Hurricaine Charley. The bend appears to be in the area just above the base plate and where the "U" shaped piece of SS is welded to the post. I hesitate just trying to bend the stanchions back into place as it appears that it will require great force to accomplish this and I can just see the the bolts and backing plates pulling out from under the deck. One of the bent stanchions is the rearmost and the screw/bolt that holds the diaginal piece to the toe rail is pulling up out of the toe rail. I want to remove the stanchions; see if I can correct the bend and replace them or purchace new stanchions.I contacted Catalina Customer Service in CA and I was told that the stanchions were through bolted. I would have to figure out how to take the interioir apart in order to get to the nuts so that the bolts and backing plate could be removed while the stanchion is removed topside. How can one get under the toe rail to access that bolt? Has anyone actually done this? I see so little space. I can't figure out through which layers the stancions are bolted, the deck, the liner and back in the head, the shower wall. Does anyone know a person with arms that are long and VERY thin(I mean Olive Oyle thin)? Can anyone give me some pointers?
