Life line specs and material
Wilco
Jul 17, 2021
9
Hunter 19 Lake Mendota, WI
I am planning to replace the life lines on my Hunter 19.
Does anyone have the specs? All the manual offers is the original part number: RI1221
Also I would be interested in hearing educated opinions on the coated, uncoated, or Dyneema option.
Thank you.
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
Joe
Jun 1, 2004
8,233
Dyneema is popular... and kinda cool... but certainly not any cheaper than wire.. I recommend SS 316, 7x7 strand, 3/16 in. diameter uncoated wire . If you're going to use existing stanchions, that will limit your options on height. It's a lot cheaper to do it yourself.... you can buy the wire in bulk and cut it yourself, (a grinder with a cut off wheel, or a hacksaw, or a jig saw with a metal cutting blade will work.) Then get the crimp fittings made by johnson... You'll have to spend $50 on their crimping tool, but it's worth it. I ordered all my stuff from www.downwindmarine.com (its part of San Diego Marine Supply) good prices.
Oh, and if you need to order stanchions, check with www.garhaurermarine.com first. Top quality, excellent consulting and fair prices.
-na -NA Anywhere USA
Check the forum store as their prices are reasonable and they know what you need as they have the build list of parts for your boat. Current owner is a former employee of Hunter who was responsible for selling parts to the consumer
Good info above from @Crazy Dave Condon, @Joe, and @sail sfbay on the issue of lifeline replacemen.
Scanning the web‘s images of Hunter19 boats, there are boats with “lifelines” and boats without. Perhaps they are not needed?
If you race your boat it would be wise to check if the rules require specific life line standards. Rules in my area require SS or Dyneema like like. Dyneema line must be inspected for chafe yearly and replaced every 6 years.
I would not use coated wire as lifelines. It has proven yo be problematic. Water gets under the coating. In the absence of air this is a formula for corrosion. The SS or common wire used rusts and crew go overboard.
SS is not too expensive. I used SS wire in the refit of my 35ft boat. Cost $660. I used the benefit of machine swaged fittings. When professionally done you get a better crimp on the wire. If this is not an emergency get a couple of quotes during the coming off season.
For your boat I think the Dyneema method would be the way I would go. The cost is in the new fittings you will need. The fittings must be compatible with Dyneem. The Dyneema material is lighter weight than SS. You need to learn a little bit about knot tying and splicing but it is useful knowledge to have for your current and future sailing.
That is my perspective. Enjoy your boat and write up your experience.
Nov 6, 2017
78
Catalina 30 5611 Stratford, Ct
Just replaced our lifelines this year. measured and bought bulk cable and used swageless fitting from Defend Industries. Hers a link to the Suncor fittings I used Quick Attach™ Archives - Suncor Stainless The best part about these is you can cut them to any length needed and they are very easy to install.
The issue of chafing, like all on a boat, can be addressed. You may have to reach a compromise; Like modifying the stanchions to provide a smooth path for the dyneema.
This is no different than putting an exit block on your mast so that you can run your halyards down inside the mast. Or getting a bigger winch when you choose a larger Genoa than the 100% jib provided by the boats manufacturer.
Boats are all a product of compromise.
