Appearance: Coated vs Plain Stainless Lifelines
When I bought my boat a couple of years ago, the surveyor noticed rust showing through the cracked vinyl of the who-knows-how-old lifelines and recommended replacing them with non-coated. Also I had read about safety advantages of non-coated. So that's what I what I did. The difference in appearance once you get used to either coated or non-coated really isn't an issue in my opinion. Actually now that I'm used to bare shiny wire, the coated type look a bit clunky to me.
The SS wire diameter for my old lifelines was the same as my uncoated new ones. If the same situation on yours, here's an idea: Assuming it's been decided to replace the lifelines, how about using a sharp razor knife to shave off the vinyl in a section taking care not to score the underlying SS wire? Two benefits: 1) You can judge the look of non-coated on your boat and 2) Maybe the underlying wire is actually still in good shape and the rusting is only on the surface of the wire (just like it is at junctions of the fittings on my two year old non-coated lifelines which have already become a bit discolored). If so, continue with the vinyl stripping and put off buying new lifelines for a while. For peace of mind. Maybe get a second opinion from a rigging shop that the underlying SS is still in good shape.
