They are available thru D & R. Follow Rudy's instructions very carefully. Especially, use only the caulk he recommends. Dow Corning 375 I think.Looking for recommendations for replacing port panels on an O'Day 322. Are these custom only? Are they available anymore? Are they flat enough to be cut from a lexan panel?
:cussing:Dow Corning 795 is the recommended sealant for plastic hatches and port lights. You can buy it in black or white.
Joe
I feel your pain. For metal hardware, like cleats, gudgeons, stanchion rails, and gunwale moldings, you want to use a good Polysulfide caulking like BoatLife Boat Caulking, or 3-M brand. For plastic which includes hatches and port lights, they recommend not using polysulfides because it will eat out the plastic. They recommend something like silicone, but silicon really doesn't adhere to anything after a while and it's no better than a rubber gasket. So this is where this Dow Corning 795 comes in. It has a combination of a silicone and other combinations that makes it very friendly to plastics, yet it will adhere like a polysulfide. When I did my port lights many years ago, I used silicone and it's been good all these years. So if you used silicone, that's OK. Let it go. On the other hand---(four thumbs and a finger) , if you used a polysulfided, remove it and get the DC 795. I still have a tube of that stuff down my cellar that I bought off Rudy last year to seal my hatch. I was thinking of removing my port lights this year and using the DC 795 but do you know what? If it ain't broke, don't fix it. It's being held on with silicone, and it ain't leaking. So the heck with it. I've said this before but it probably deserves repeating so that you and others do not fall into the same trap that I did years ago; Be careful of hull and deck cleaners that have Oxalic Acid in it. It will eat out caulking. You know, these helpful hint books that tell you to use a product like Zud Cleanser with OA in it because it will clean the stains out of fiberglass. It will do that, but what they don't tell you is that it will eat the caulking right out of your gunwale moldings and your boat will leak like a sieve. Been there, done that. A word to the wise, is sufficient. I agree with you though. Caulking is expensive, but if you do it right, and wash your boat with good ole' soap and water, it will will last 10 or more years. The best of luck!:cussing:
ahhhhgggghhhhaaaahhhhggggg!!! That's what kills me about sealants. So much conflicting information... i am in the process of resealing just about everything on my boat but my wallet. i have read and questioned just about every book, read every post and asked everyone I know, including the custodian at work! In MainSailors article for installing NFM ports, he used butyl and 3m 101. Rudy says use something else. Ed K is using buty this year on his forward hatch..Everyone has used everthing and it all seems to leak from the start or never had a leak in 30 years....ahhhhggghhhhhhhaahhhhggggg (that was supposed to sound like "the scream")
Hey Keith,thanks joe, boy, sealent discussions are like wine discussion (or beer), there are alot of different styles, but only a few basic types, and everyone has varying opinions and experiences.
I decided to use a propriety silicon that has a little polyurethane that i know you have heard of, life seal. I decided to use that on the plastic ring that goes around the port, and i will use butyl tape to seat the spigot, (am i using the right nomenclature?)
i came up with that by reading main sailor's article on seating his nfm ports, which are of the same basic type as mine, but of course his are the cool and high dollar stainless steel.
i wonder if i could sneak an order for those things by my wife..........nah, probably not
keith
Hi Ed,Hey Keith,
"His wife was going to throw them them out, and we're talking books like "This Old Boat", four or five books by Don Casey, and Nathanael Bowditch to name a few. " I should be so lucky. But then you are near the ancient heart of American Mariners.
"I used 3-M polysulfide 5200 caulking. I think it's polysulfide. It's not silicone. Anyway, I just stepped in the stuff and tracked it on my deck. So I know one thing about this stuff. It's messy! Joe"
5200 is one of the oldest used in sailboats and still used by many manufacturers. There is an important issue. Once you use it on fiberglass, it is permanent. If you ever have another issue at that spot, you damage the underlying FRP getting it off. It is a major PITA.
If that spot develops problems, it is a major project whereas those labeled removeable, i.e., 4000 or 4200 and others, can be more easily removed for fixing what ever the issue is.
Tell us in a couple of weeks how the spots that you tracked around look. Then I will tell you about a product that is hard to come by, but softens the culprit. And it is not the stuff sold at WM.
Ed K
O'Day 26 as featured in 'Good Old Boat' of May June 2009...
Just checked a tube of Lifeseal and it says it's safe for plastics. Specifies Lexan, ABS, and a few others. I have a couple tubes of white, but I guess I'll pick up a tube of black now.
From their site
A unique combination of marine silicone and polyurethane, formulated especially for fiberglass. Life Seal® offers a fast-curing, low odor, high adhesion, non-sagging, non-corrosive, non-yellowing formula. It provides a durable permanent watertight seal for joints subject to structural movement. May be used above or below the waterline. Use for sealing decks to hulls, thru-hull fittings, vinyl ports, sealing/glazing windshields and bedding marine hardware. Will adhere to metal, glass, wood, Lexan®, ABS® and certain other materials. Can be removed without damaging gel-coat. Not recommended for ferro cement hulls, impregnated wood or oil-soaked materials. Cures in presence of water. Mildew resistant and acid-free. Custom colors available.
Maine SailBe careful with that wording above! It says "Will adhere to metal, glass, wood, Lexan®, ABS® and certain other materials." ! Sure many products will "adhere" to Lexan or ABS but will it damage it? Will it eventually leach the plasticzers from it and make it prematurely brittle? What it does not say is things like "safe for use on Acrylic" or "Safe for use on polycarbonate/Lexan".. Adhesion is only half the battle with Acrylic or Lexan.
I'd find some Dow 795 if I were you and you're sealing polycarbonate or acrylic dead lights. It will be CHEAPER and will work better for sealing Acrylic or Lexan ports than just about any product on the market. I would strongly advise the use of Acrylic over Lexan/Polycarbonate though..
As for my NFM port lights, discussed earlier, they are stainless steel so they can be bedded with a variety of products seeing as compatibility is not an issue. They are also mechanically fastened. I like butyl and polysulfides but NOT for Acrylic or Lexan..
Acrylic dead lights need a product specifically designed for that application and Dow 795 is the preferred structural Silicone for the task. If you have plastic Beckson ports Dow 795 also works very well and Beckson specifically advises against polysulfides or polyurethanes..
