Lewmar Portlight plastic trim for pre 1997 models
10
Catalina 36 mkII Preveza, Greece
Has anyone been able to source plastic interior trim or make-up trim kits, for older Lewmar Portlights, as these are no longer available to purchase from Lewmar or Catalina directly. I have a 1996 Catalina 36 Mk II.
Jan 4, 2006
262
Catalina 36 MKII Buford, Ga.
You should be able to find these at catalinadirect.com
Go to Catalina's >30/ hatches and ports/ then choose gaskets or port lenses
By the way, if you are not already a member, you should consider joining the C36 association at www.C36ia.com There is a lot of information and help there!
Catalina 320 Dana Point
Catalina Direct had the last of these made by Lewmar a few years ago, I tried ordering some.
One alternative I considered was replacing the whole portlight, I'd found some online for around $200 USD.
Replacement parts were $95 for the lens, $35 for the gasket, 35- 40 for the screen, and the plastic trim on the inside was unavailable (priceless) so if you need the rest it doesn't seem so out landish. For a little more you can get the polished frames like the new boats.
http://www.p2marine.com/catalog/product_info.php?products_id=5483
Polished Stainless
http://www.p2marine.com/catalog/product_info.php?products_id=5484
Dave Groshong
SBO Staff
Staff member
Jan 25, 2007
1,867
Catalina 22 Seattle
You can find the Old Standard lenses, and parts, at SelectPlastics.com
Tell Tony, Dave from SBO sent ya!
