Lewmar Electric Winch Popping Breaker
16
Hunter 380 Long Beach
98/99 Lewmar OP2 keeps blowing the breaker as I try to raise the mainsail. This starts occuring at about half way up and can hear the winch laboring. Checked connections all the way to the motor and are clean. Do not think it is being overloaded as I can hand raise the sail at the mast. Called Lewmar, said for me to buy a new winch because the OP2 is no longer supported, not even a suggestion on a possible solution.:evil:
Any thoughts?
Thanks, Brian
Jun 6, 2006
6,990
try raising the sail from the winch. Bet the deck organizers have worn blocks.
Feb 10, 2004
4,154
Hunter 40.5 Warwick, RI
My OP2 sometimes trips when I'm trying to get the last foot and a half of the mainsail up.
The only other time my OP2 pops the breaker is when my wife hauls me up the mast. She has her own theory...
JWC
Aug 28, 2011
29
Hunter 40 Phuket
Check the current draw with a clamp meter when in use with load/no load. If this is less than the breakers rating you need a new breaker.
