John
The Lewmar electric winch on our 1999 380 leaks gear oil out from under the drum after we winch up the main. It is enough oil that it runs out on the surface and it can get on hands or lines around the winch.We wipe it up with a paper towel.It is not winch grease. We have redone the grease according to specs and the three other winches do not have the problem.I took off the access cover below in the aft cabin and everything seems OK there. All bolts are tight and there is no leaking gear oil present.Any ideas?Thanks
