I've developed a noise coming from the linkage on my Lewmar Cobra drive. It sounds like it is under the cockpit sole so I'm assuming that it is part of the linkage from the pedestal arm to the rudder stock. The sound is something like a loose fit between parts since it happens when the rudder changes position during slight changes in wheel position (slight turn to stbd after a turn to port). There isn't much in the way of literature on the Lewmar website so at this point I'm not sure what the problem is. I'm concerned that one of the rod eye's may have a loose mount on the arm.
Couple of questions:
A) Has anyone with the Lewmar cobra drive had this problem.
B) I need to remove the cockpit sole to access the drive. Looks like only 4 screws to remove. Has anyone done this and are there any special precautions I need to take when removing the sole?
This is a 2008 Hunter 36
Any reponse is greatly appreciated since I feel a royal raping from the boat yard on this one.
