Lewmar 65 Electric Winches
capta
Jun 4, 2009
5,075
Has anyone here dismantled a Lewmar 65 Electric Winch? Did you find adequate instructions anywhere? It is a daunting project and a bit of advice from someone who has done it would be greatly appreciated.
Thanks in advance.
Catalina 320 Dana Point
I keep forgetting there's a video of EVERYTHING on You Tube, last week I fixed the Admirals clothes dryer using one.
I usually let the metal parts soak overnight in mineral spirits, the last guy always used way too much grease and after baking for a decade it's harder than diamonds.:eek:
capta
Jun 4, 2009
5,075
Thank you very much for your replies. Though these winches are pre-ocean series, I believe the info supplied is sufficient.
I had a problem w/ the electrics and was wondering how the motor is removed, but it's working OK now. I will have to do it one day soon though, because it seems we have a flat spot on the commutator. However, I learned this morning that if I partially insert a winch handle (and keep my thumb clear!!!) I can get it going again, for now. As we're going south this week it will be a project for a nice tropical anchorage in the Grenadines.
Thanks again,
Andrew
