Lewmar 40ST winch repair
14
Hunter H340 Cobb Island Maryland
Broke my stripper ring on one of my 40ST's. Now lines jam if not careful. So going to order new one and a spare also. Do I need the kit or just the ring? Also, Does the pan head screw allow the crown to be taken off or is there a trick that I am not seeing in the blow up? Thanks a milliion.
Feb 27, 2004
172
Hunter 335 North East, MD
You should just need the stripper ring- the very top of the winch unscrews (at least it did on mine) and will give you access to the guts of the winch. Lewmar has a good website where you can down load and print a pdf for your winch
Rick D
Jun 14, 2008
7,203
Ditto nveater. I had a crew do a wrap and crank it down. It bent the line ramp (stripper) and it was toast. The fix took five minutes. They are not cheap tho; maybe a C note.
Aug 1, 2011
14
Thanks. Should be a easy fix (knock on wood). Its part #6 on the blow up. About $20ea. Really sux when it breaks and you are not paying attention and jam a line. Takes some effort to pull back through if you can while under sail instead of taking apart.
