There are a lot of jib furlers out there, & everyone has their opinion on what is best.
Pro Furl have a good reputation & claim to have a system that prevents halyard wrap at the top of the mast.  I had a boat with a Harken, new Mark III model & it was nothing but trouble.  Jammed up all the time, not matter how it was rigged.  Flexible furlers are a little less costly to buy, & are easier to service & repair down the road.  You usually do not have to remove the mast to install a furler.  Most slip over the existing head stay & spin round the stay when operating.  Make sure that the haliard swivel at the top of the mast does not wrap around itself, as this is a common problem, that will cause the furler to jamb.
I have found that the most important thing to watch out for when using a furler, is to make sure that you keep tension on the furling line when unfurling & to cleat the line tight, so that it cannot come loose.  I the furling line gets slack in it, it can allow the line to roll off the drum, & cause it to jamb up on you.  Furlers are great when they work, & suck when they don't. But I would not sail without one, as hank on sails are tiring.  You will likely need to purchase a jib sail that was designed to work with a furler as they are cut higher to fit the furler length, & have luff padding at built into the sail to prevent it from getting baggy when partially furled for better performance.  A furler is a real, but expensive investment in your boat, that can pay big rewards when they are installed & work properly.  Don't forget to have a sacrificial strip of Sunbrella fabric sewn onto the outer edges of your jib to protect it from U.V. damage, as the Dacron will fall apart after a year of not being protected from the suns harsh rays.  Expect to pay a couple of grand for a good furling system, & another $1,500 + for a new jib sail built for your furling system.
