Length of halyards?
75
Hunter 31_83-87 Key West
I've got to replace both the jib and mainsail halyards. Does anyone know what length these lines should be? Scott Fraser Key West
SeaRanch
H31 83_87 Halyards
When I replaced the Halyards on my '87 H31, I purchased off the shelf 7/16" halyards from West Marine, they have been working fine for several years.
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
Strong Suggestion...
...that you consider using a smaller diameter line. Large diameter line has a huge amount of turning friction. I use 3/8" halyards on my 35.5. That is plenty strong enough and easy to handle.
Dec 2, 1999
15,184
Don't use any larger diameter.
Hunter's original spec's called for a 1/2" main halyard x 110'. We found that it was binding so we stepped down to 7/16" and it works much better now.
May 22, 2004
1
Hunter 356 Rockford, MI
halyards
I was just up the mast on my 1984, it is 42-0" from top of mast to top of deck, I am replacing my with 3/8.
