a good repair shop should not be afraid to take it on, others will whine and try to sell you a real engine....parts are fairly easy to source for the Lehr, if needed...oil is oil and so on. Same tools will handle both, with the exception of the carb...and they are generally pretty reliable, as the usual gasoline gunk is not an issue.
