led wiring?
Oct 17, 2014
3
Columbia 8.3 Escanaba
I have switched some of my interior lights to led bulbs and they work fine. Two other small wall lights in the cabin will not work with an led bulb. Can I just switch the leads on these two lamps to correct the polarity, or will that mess up the entire circuit?
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
just swap the leeds at the light only and see if they work if so use them just mark the wires after so you will know which is which....but first make sure you are getting power in those wires
Oct 24, 2010
2,405
Hunter 30 Everett, WA
If all you are switching is the light polarity, it should be fine. Just be sure you don't switch wires that are daisy chained to other things. You should be able to remove the light and verify what you are changing. I'd personally put a volt meter on it to check polarity.
Ken
May 24, 2004
7,228
CC 30 South Florida
I think he is saying that regular lights work as currently wired. You will still need to reverse the wiring at the socket to correct polarity for LED bulbs.
Islander Freeport, 41 Ketch Longmont, CO
I believe LED bulbs are polarity sensitive (in most cases) so you have to ensure you have + to + and - to - wired correctly. If the bulb doesn't work, in a fixture reverse the wiring or in the case of Festoon's, reverse the bulb.
good luck,
