This light doesn't work. How to remain
it? Challenging to me.
The toggle switch will not allow any turning of the trim ring. There are several dimples (3??) in the ring that hold it on. One can be seen at about 10 o'clock in the OP pic. So @sailsfbay has the answer, pop it off. Either a good strong finger nail or a thin blade and lots of care so not to damage the headliner will do the trick. With the ring off, 3 screws will be exposed so you can lower the fixture and disconnect the 2 spade connectors. There should be no need to replace the complete fixture. No doubt a loose connections or the bulb is unserviceable.I will make a wild guess and suggest popping the outer ring off the light......that is what I recall when I replaced a similar light on my Hunter 386 a number of years ago.
