Lectra/San unit on a H31?
- - Bullock Cove, RI
I am considering installing a Lectra/San unit on my '86 H31. Has anyone out there done that, and if so, where did you put it, etc. Any info will be appreciated. Thanks.
Dec 2, 1997
9,011
- - LIttle Rock
In RI, there's prob'ly not much point in doing it
'Cuz all RI waters are "no discharge"...which means that toilet waste may only go into a holding tank that can only be emptied by pumpout. So unless you spend most of your time cruising outside the waters of RI, you won't get much use out of a Lectra/San.
Thanks for the comeback Peggy, But...
I do most of my cruising outside RI waters. I cruise MA, LI Sound, & Conn mostly during the Summer, and hope to go South to FL/Bahamas (again) this winter. The laws vary in different states, but the way I look at it is whatever they are, using a Type 1 MSD is just plain better under any circumstances. By the way, I have your book, and it's very helpful.
Dec 2, 1997
9,011
- - LIttle Rock
In that case...
Go for it...you'll love the freedom from holding tank maintenance. Follow the installation directions carefully and it will give you decades of odor-free, trouble-free service. The Installation and Maintenance Guide are on the Raritan website at http://www.raritaneng.com It should answer most of your questions about where to put it and how to plumb and wire it correctly.
