Leaving boat in water
173
Catalina 350 Rock hall
Yes my boat is in a de iced pier, and the water is slightly brackish so ice I think is minimal
Mar 29, 2011
169
Beneteau 361 Charlotte,Vt
With all this talk about being crushed by the ice. Two different years, up here is frozen wasteland of Vermont winter. Someone decided to live of aboard over the winter. A normal winter, we get ice from December to March in the range of 3-4 feet thick. I can't be sure, but I believe they were fiberglass hull sailboats. Both time, the boats were left in the mooring field in the fall, froze in for the winter and sailed away in the spring. This was in Mallette's Bay on Lake Champlain. The last time, just a few years ago, they may have used a bubblier system, but the first time I remember someone doing this it was back in the 70's and they didn't so anything. I'm not saying I would store my boat this way, hell mine has been in the cradle since October. Just thought it was interesting.
Merry Christmas
Mike,
Gunni
Mar 16, 2010
5,937
Read your insurance policy - most marine policies require a "lay-up period" where the boat is not navigated. Typically 120 days. If you are sailing during a layup you risk having a claim denied.
Jun 16, 2011
173
I gave read that in here, so I called boat us and they said I have a yearly policy and it is fine to not lay up for the winter
Mar 26, 2011
3,837
Corsair F-24 MK I Deale, MD
But as a sailing buddy said last time we were out ant it was cold, if you had a problem, there is no one in sight and who's coming to help you? But when everyone is gettin thier boat ready in the spring, I'll be all set.
Yes, it is a bit more like sailing off-shore. The winds are generally greater; sailing in a small craft advisory is normal. You must be self-sufficient.
You must not fall of the boat. A small boat caspized near my port last weekend, and one died from hypothermia. Every boat should carry a wet suit or drysuit, in case there is cause to go for a swim.
Ice can be a problem for the prop, even if quite limited. I won't go if there is any as the sound of chopping ice is disconcerting.
Beneteau 323 Annapolis MD
...You must not fall of the boat. A small boat caspized near my port last weekend, and one died from hypothermia.
Thin, I believe the 2nd crew died in, or is in, the hospital and they still have not found the third one.
Jun 2, 2004
1,077
Several Catalinas C25/C320 USA
My boat's been in the water for seven years. It does fine, a bit of growth on the bottom, not bad. Water does not freeze, so that's no problem. I winterize the engine and water system...lots easier and cheaper than pulling it out.
Jun 3, 2004
418
Island Packet Island Packet 29 West River, MD
Read Your Insurance Policy "Exclusions"
I'm not far from you in the West River. I sail thru December every year and winterize after Christmas. Water tanks, holding tank, head, engine, all the usual stuff. Every winter we do get a bit of ice for a few weeks and it's not thick. Myself and three others around me all have bubblers so we're OK. I do think Warren Millberg makes a good point that bubblers are only as good as the electric that runs them. If we get a bad storm and power goes out for a few days we could have a problem but it's one I'm willing to risk. I haul every year for a week or so and do the bottom, etc. My reason for this approach is mostly to save the money.
That said read your insurance policy. If you happen to have State Farm as I do the policy reads:
"We do not insure for loss to the property described in Coverage A either consisting of, or directly and immediately caused by, one or more of the following: freezing, thawing, pressure or weight of water or ice, whether driven by wind or not".
Like Stu Jackson always says "your boat, your choice".
