Billy C:
I'm surprised so few responses to your post considering the safety implications. Sorry to be alarmist, but I'm in Hermit Scott's camp. Given that the leakage rate for a healthy thru hull/seacock/valve is normally zero (in its lifetime!), something is seriously wrong about "less than a gallon a day". Please consider not to put your boat back into the water until all the thru-hulls components are competently fixed. A sunken boat is the risk of not acting. If all three thru-hull areas are leaking and they are all of the same type, then they are likely failing in the same way which is worrisome. Maybe a previous PO incorrectly installed new hardware or did a band-aid fix which is now failing. If the fittings are bronze (and might now have been on the boat for 20+ years), maybe the metal has turned pink. Scrape away the surface tarnish both on the inside and outside of the hull. The color should be clean metallic gold yellow --- if pink, the bronze has been attacked by galvanic corrosion and is likely very brittle, cracked and could be near complete fracture. When opening/closing the seacock/valve on the bronze fitting, one day the valve might break right off the pinked bronze thru-hull and you'll be watching the water gush in. On the inside of the hull, are there plywood backing plates? If so, are they water logged and soft? Does your O'day have a cored hull below the water line? If so, the interior wood may have softened and the thru-hull fitting is no longer tightly mounted. Maybe the hoses are cracked or the hose clamps loose. Maybe the valves might be leaking through the stems. Many possibilities, but the problem(s) really must be fixed or the boat is not safe.
