Hi,
The correct URL of your picture is
http://www.aquatrends.com/vega/stemgland.jpg
You appear to have the stuffing box type of stern gland, but the grease tube
is not attached to teh fitting on the top. Have you been pumping grease into
this occasionally? (There appears to be some old grease round about the
greasepump fitting)
If the problem is not a lack of grease then you will need to repack the
stern gland. New packing will cost you pennies, but unless you are very
brave you will need to lift the boat out of the water to do it. Apart from
anything else, getting the old packing out is the easiest way to check the
size you need.
Good luck,
Nick
'Fairwinds' V1842
Oban, Scotland
greasepump fitting)
size you need.
Good luck,
Nick
'Fairwinds' V1842
Oban, Scotland
