Leaky Cockpit Rudder Post
Peter
Have a 1983 Cat 30 with a bad leak that occurs when rain water drips through the base of the rudder post that attaches to the emergency tiller. This drips down on the aft cushions inside and is a royal PITA. Since I would think this is a common problem for boats of this vintage is there a standard repair?? Thanks.
jamie
leaky post
Hi I had the same problem and just used a little caulking to seal around the bushing on the post and build a little ridge so the water that drains out from the aft lazzerett is directed to the cockpit floor ant not twards the post ,good luck
