John Evans
> Hello folks,> > This may not be the appropriate place, but, here goes.> I own a 1976 Catalina 22.> I've owned it for 13 years, and I love it.> I have one small problem.> When I run under power (Outboard Yamaha-6), water enters the bilge.> From where I don't really know, because I can't see it.> In an hour's motoring, 15-20 gallons will enter.> Then I have to spend ten minutes or more pumping out the bilge.> > I had the bottom painted last October, and I asked my mechanic(Mainsail> Marine, Chesnee, SC) to try to correct the problem. He tried, but didn't> get it fixed. He thinks there is a hole in the slot where the swing keel is> stored when raised.> He said it would be so tight inside the slot, that we wasn't sure he would> be able to fix it. He was right.> > Any answers or suggestions?> > Thanks,> > John Evans> Evans Engineering Associates> 744 Sunset Blvd Suite 203> West Columbia, SC 29169> 803-791-1446> FAX 803-791-1861> email jevans@evansengr.com>
