Troubleshooting leaks
Hi Gary -It can definitely be frustrating trying to find the source of some leaks. Since it appears you have several, and have been unsuccessful so far, you might try pressure testing from the inside of the boat. You'll need a roll of tape, a large shop-vac, cardboard, and a dry day. Start by making a template of one of the hatch boards out of carboard. Then tape every exterior hatch, port, and locker - fill dorades with rags or anything to seal them. Cut a hole in the cardboard companionway hatch board you made and tape the vacuum hose (hose inserted in the exhaust side of the unit) into it once it's in place. Turn on the vacuum. Now spend some time on deck with a solution of water and soap, spreading the solution on (and in) any areas where you think water might be entering (check that hull to deck joint!). If you see bubbles, you know you need to rebed or seal that area. The entire process shouldn't take more than a couple hours.Best of luck!Trevor
