Have done my "detective" work and have concluded that the water (albeit a small amount) accumulating in the bilge is from a leaking keel bolt. If I tighten the bolt, assuming I can, should I expect that to fix the problem or should I expect to apply some sort of sealant. Hoping I can fix the problem without a haulout. The boat is a 96 H37.5
